Hi, new member here from the UK recently purchased a Rotax.
The UK forums are dead so I though I’d sign up here
I’ve used a new bead breaker for the first time today and it’s scratched the wheels where the wheel sits on the curved alignment jig.
Is this normal? I’m not impressed to be honest the edges are sharp, I didn’t realise until it was too late.
Many of them are the same design over here, surely it can’t be right.
That looks like more than a scratch. Its tough to tell from the pic, I assume you are showing the centering ring and not the part that is breaking the bead.
Make sure there isn’t a rough spot, raised weld, causing this issue, may have to grind some of the edges.
I think you have hit on something we are all seeing, products being made cheaply with lower quality but looking like the original. AS always Caveat emptor.
