Moved (20 characters)
im 12 cadet is from 8 to 12 im moving from lo206 cadet to ka jn in a few mounts and i posted the race like 5 minutes ago
Does hopping like that help? It seemed like you actually slowed down when you did that.
idk if it helps probaly does not
Hopping does help but not there. It helps (my 93kg anyway) coming out of slow corners - idea is it allows the rears to spin up that lil bit faster as you get back on the gas. If you’re already settled into a high speed corner/straight it’ll slow you down by removing traction. Generally I’ll do two hops as I get the power down then do the human drs thing (5’11) along the straight. 4 strokes def, not so much on 2 stroke.
thanks for the tip i probably should have tucked under my wheel instead
