Current Go-To axle bearings
Is there a go-to on axle bearings these days? Price vs quality. Nothing crazy, just a good quality choice that is readily available.
Just throw some cheap ones in and replace every season. Align the axle correct and you are good to go
Any links to what you consider cheap? I cringe with cheap but I agree if you can get away with just changing them often and they are just as good…
These for example. Running them on my KZ energy kart. Excellent, they are in C4 specs so slightly more play than C3 most karts come with
Thanks Lucas! I’ll look them up now.
Sweet!
Align them well, I just align with the outer bearings first. Then if you have a third bearing I tend to install the casette after you have align the outer ones. Remove axle and remove the right outer one and align the third casette towards the left one and you are 100%
I’m glad I decided to get new. The right side was pretty crunchy…lol
