Identify crg brakes
Hey everyone, this is my first post on this platform. A friend of mine recommended it. Since I’m struggling with something, I thought I might as well ask here.
I’m having trouble figuring out which brake caliper and master cylinder I need. Unfortunately, I’ve come to the conclusion that the master cylinder needs to be replaced because it’s leaking.
The second issue is that I didn’t attach the caliper properly, which caused it to fall onto the brake disc. As a result, both the brake disc and the caliper were damaged. The brake disc ended up bent, and the caliper might have hit an oil channel — but I’m going to try fixing it first with a brake rebuild.
The brake cylinders in the calipers are also worn out, so I want to do a caliper cylinder rebuild as well.
So, in total, I need to find the correct master cylinder, caliper, and brake disc. This is a kart that I bought from someone, but they also don’t seem to know what brake system it has. I’ve tried searching online but couldn’t find a good match, so I was hoping you all could help me figure out which parts I need.
(This is regarding a crg with 2017 homologation, rotax senior and the total width of the brake cylinder is 28mm)
It’s CRG Ven11 system :victory_hand:t2:
