Hello I went in the garage to start my l0206 and the choke would not stay up it would come down without sticking or staying at all anyone know the problem
You don’t want it to be able to stay up. Hold it up while starting, if necessary and then let it go. 9/10 times you shouldn’t need to touch the choke anyway.
Hey man thank just did it and it worked
On the LO206 is the choke lever only really used for starting?
Don’t use the choke. Ziptie it shut. Fill the float bowl with gasoline by blowing into the vent line. Start the engine by pushing the throttle halfway open and roping it over.
