M10 steering column for 2015 Tony Kart
I just realized my 2015 Tony Kart Racer 401 has a M10 steering column, which is different than the currently available OTK steering column (M8).
Does anyone know if there’s still original OTK M10 steering column available?
Or is there a way to convert the uniball to fit the new M8 steering column.
Thanks !
You will have no problems randy . The thread m8 changes only at the end of the column .
See the details here .
Thanks, that’s great to know the uniball bearing are the same.
I tried it this weekend, the shoulder part on the OTK M8 steering column is same as M10, so it fits through the uniball just fine.
But beneath the uniball there is a spacer to allow full rotation of the uniball, this spacer fits over the threaded part the M10 spacer is too big to fit the m8 steering column. I think with the m8 uniball spacer, this should work fine.
