Tony Kart with M6 Bodywork
I wonder if i could put the M7 Nassau Panel,Mounts,Spacer
Yes the M7 panel should fit just fine it uses the same mounting points and brackets as the M6
I’m pretty sure the lower bracket for the M7 panel is just a bit shorter than the reg M6 panel. Not a big deal, just cut and re drill
sorry i responded extremely late
will i benefit from the top bracket spacer
