Rotax Fr125 max temperature sensor
I would like to know where the hole is located to install a temperature sensor on a Rotax max Fr125 2013. Thank you!
https://www.google.com/url?sa=t&source=web&rct=j&opi=89978449&url=https://www.scribd.com/document/557260454/Rotax-Karting-Repair-Manual-Fr-125-Max&ved=2ahUKEwi-orThxeSGAxU9_7sIHVRCDt0QFnoECBUQAQ&usg=AOvVaw0X4S3Oi1V10t4kpCMTkjJf
If you want to check engine temp ,.it depends from the type of sensor plug you got . Some of them are going on the spark plug head as a washer on their thread .
So many questions for you engine . Means that you can have great help also by start reading its manual .
https://www.google.com/url?sa=t&source=web&rct=j&opi=89978449&url=https://www.kartservice.nl/pdf/DOC_Handbuch_Rotax_MAX.pdf&ved=2ahUKEwiehreJx-SGAxVT7rsIHQVPBkYQFnoECBAQAQ&usg=AOvVaw1EO8lz7BEEjCtnJfvH_dNT
OK! thank you, and yes you are right, I had a lot of questions that I couldn’t find in the book. I have this manual, thank you! I believe the sensor goes to this location, 1/8 socket and my sensor is a 1/8, I managed to find this yesterday, and I want to be sure, so as not to break anything. Red point
Intimidating Oh Yeah GIF by Laff
