I am new to karting and I would like to get some advice on running my RPM wire safely and securely, maybe learn from the experiences others have had. (Triumphs and failures)
Above is fine. Or run it with your fuel line or throttle cable. I like to run them all 3 together in one bundle and then loosely daisy chain zip tie them to the frame (to avoid pinching).
What do you think about running the wire inside some tubing (fuel tubing 'cause that’s what I have) to protect the thin wire from rock and debris damage?
