thoughts on this riccairdo chassis with lo206… also any response on settup for this chassis…
I mean, it’s a Birel. If you take some time to set it up, it’ll be quick, like with most karts.
Ricciardo is a good make, as Davin said it’s the same as a BirelART, so it’s quality. As with any kart, I would start at the baseline setup (medium axle, medium hubs, neutral caster/camber, etc.). That’s usually a good bet on most major brands.
They look good, so that’s a thing. How does the support for the Birel family look in and around the series and tracks you plan running?
