Problem on long sweeping carousel tun…
It’s a 4th gear turn at constant speed with
3/4 steady throttle at 11500 rpm.
Motor sounds like is 4cycling until I can go full throttle on exit…… it pulls hard and clean to 15k when I exit , and go up the gears…
Is this likely a clip position issue rather than main jet ?…. Only running 1175egt on a 80 degree day .
Thanks in advance ,
Bill
