Vortex ROK GP clutch sprocket, looking for a 16T. Would a Rotax sprocket work? they look similar but wasn’t sure.
Yes but…By the driver sprocket size, I’m thinking you are roading racing. Here’s store (Fastech Racing) that has some information on what needs to be done. There is some re locating holes but I’m not sure that can be done by hand, may require a milling machine. The Rotax clutch center is more robust than the GP clutch. See link.
Search results :: Fastech-Racing, Inc..
IF you modify tell us how it worked out.
Rok GP Roadrace package 17t I kept on researching and found this, I may check with the Roadrace guys see if anything is used $475 is a tough pill to swallow.
