WKA Tech Manual Update #3 for 2019
(James McMahon) #1
A Press Release from: WKA
send press releases to [email protected] kartpulse.com
Pit Board
Hello,
Today’s WKA Pit Board is brought to you by…
unnamed%20(2)
wka
CONCORD, NC - The following Tech Updates were approved by the Board of Trustees, and are effective immediately.
  • 115.1 – HEAD GEAR
    Add: Snell K-2015 Helmets are permissible in all WKA Sanctioned Events, no earlier versions
  • 214.5.1 – KA100 JUNIOR
    TIRES: One new set of tires required each day for qualifying.
    CHANGE TO: One new set of tires required on day 1. The same set must be used for qualifying on day 2.
  • 214.6 – IAME JUNIOR
    MINIMUM WEIGHTS: 320 lbs.
    CHANGE TO: 330 lbs.
  • 214.9 – KA100 SENIOR
  • 362.10 – TAG JUNIOR, Final 1 & Final 2
    Add: Rotax FR125 Jr is permitted, (see section TM-609 for engine specifications)
  • 312.10 – UNLIMITED FINAL 1 & FINAL 2
    DELETE:
    Ignition: OEM Only
    Transmission: OEM transmission ratios only. Components may not be machined to reduce weight. Clutch discs, plates, springs, and hardware may be aftermarket. Slipper clutch, axles clutch, or Sprag units are allowed.
To view the Tech Manual Update page on the WKA website and view all the updates from 2019, click the button below:
Tech Updates
Did you miss a Pit Board? Click the button below to visit our website to view and read all archived pit boards and more!
WKA Website
For all the latest news, be sure to follow and like our Facebook, Twitter and Instagram pages below.
FacebookTwitterInstagram
(Alex Christie ) #2
I’m a big fan of the “one set of tires” for KA classes!
