What is peoples opinion about this spacer, with or without ?? I have upgraded my x30 to the new “one piece” exhaust. But on the old one, there was also the tube to play with, that would changes how the torque was delievered, top speed etc.
I guess you can run it with or without the spacer, just make sure you run the gasket to prevent any leakage. Exhaust is crucial for 2 stroke tuning, a leaking exhaust is a killer.
As for the spacer, it’s just what it says… spacing more length to your exhaust… the longer it is, the lower your power band moves. Shorter exhaust length is higher power band.
If someone can do some dyno pulls with and without the spacer we can have some data.
Thanks guys. I think I have to try myself then. I was just hoping, someone had done a real world testing
My mechanic told me, that I would gaine a little more torque in the middle band… And since our local track is a very technical track, with very little high speed, it would make sence to try.
