Do different stiffness axles do anything?
Bingo! Axle is a big change and affects a ton of variables so it’s usually a last resort change for me. Short N is what I run 95% of the time.
#1 - I am a Mech Engineer that has 25 years experience in the pump and compressor industry. I now work in sales, but still regularly get consulted for input on difficult technical field issues and failure analysis. But don’t hold that against me…
#2 - The modulus of elasticity of all steels is in the range of 28.5-31 x10^6 psi. “Strong” steels are not “stiffer”…they just can be deformed further before they yield. Even radically different alloys like Martensetic SS, Austenetic SS, and high alloy steels have the very close to the SAME MODULUS. So from a static deflection perspective, all steels are the same. There is no such thing as more or less flexible steel when you are in the elastic range (before you bend…or go plastic) Even look at Maraging Steels…the most exotic high strength steels in existence. 18Ni Mar 350 Rockwell C = 57. Tensile = 342,000 psi. Yield = 336,000. YES…those stress numbers are correct. Here is the kicker. Modulus = 30x10^6 psi. Pretty much the exact same as 1018 steel. So if you get a $10,000 18Ni Mar 350 axle made, it wont feel any different, but you will NEVER bend it, if you can still afford to race.
Steel Grade of Tubing (US Spec) Tensile Yield Hardness Modulus (10^6 psi)
1008 CW 49300 41300 55 RB 29
1010 CW 52900 44200 60 RB 29
1018 CW 63800 53700 71 RB 29.7
1020 HW 60900 50800 68 RB 29.7
1026 CW 71100 60200 78 RB 29
A106 Gr. C (High Temp Fluid Handling) 70000 40000 100 RB 30.4
J524 (good for bending) 45000 25000 65 Brinnel
4130 81200 66700 95 RB 29.7
4140 95000 60200 92 RB 29.7
4340 108000 68200 95 RB 29.7
Modulus are all in the 29-30 x 10^6 psi range… and heat treatment does not change it much either. It is what it is.
#3 - Hardness of steels, in the correct materials engineering sense, has nothing to do with what we are talking about. Hardness of a steel is determined by striking it with a die of some sort (such as a small very hard round ball, etc), and measuring the size of the indentation when the steel, meaning it has yielded and gone plastic. In other words…localized bending.
#4 - What about damping (the propensity of a material-structure to not spring back quite as hard as you pushed on it) you say? Well all steels have relatively low damping, but I will acknowledge there is not lot of data on damping.
Here is one paper, from the Library of Congress - https://stacks.cdc.gov/view/cdc/10399/cdc_10399_DS1.pdf
You will note there looks to be some difference between the damping of different steels. At 5000 psi (maybe a good number when your kart loads up and hops/jumps in a corner) specific damping runs from 0.2 for 1045…to 2.0 for 1020…so the lower strength steel has more damping (Page 12). Heat treatment does increase damping some…such as for 1144…0.4 to 4.4! (Page 14)
But even these numbers are low. Grey Cast Irons (flake micro structure) have Specific Damping ranges in the 15-25 range! Have you ever seen a machine tool body made from steel? Do you know why? It is not because machine tool mfgs are cheap…it is because CI is the ideal material for large precision machine frames that you want to run smooth. Lots of damping, but expensive to move. And they are brittle materials…which are not a good idea for applications like a kart axle.
That is really all there is to it. You have Modulus (the “spring constant” of steel)…which never changes much. There is some range in damping. So if there indeed is a difference in kart axles, it can only come from one of two areas:
  1. Making the wall thicker or thinner, which no one seems to be doing. For instance, ALL (6) Birel-Freeline Axles are 50mmx2mm, the 2mm being wall.
  2. So if you feel a difference, it must be due to damping…say 1045 annealed vs 1144 heat treated.
There is simply nothing else.
I enjoyed reading that a lot. I feel both smarter, and a lot less so!
I found another damping reference which shows that Martensetic SS (410/416/420 SS) has the highest damping of any steel.
Schetky and Perkins1 have studied the damping properties of metals and alloys. They identified the malleable magnesium as the most damping metal (specific damping capacity - 49%), followed by the alloy inkramut and sonoston - 40%, Nitinol - 40% saylentelloy - 40%,high-carbon cast iron - 19%, nickel (net) - 18%, technically pure iron - 16%, martensitic stainless steel - 8%, gray cast iron - 6%, mild steel - 4%, ferritic stainless steel - 3%,malleable cast iron with spheroidal graphite - 2%, medium carbon steel - 1%, acousticstainless steel - 1%, aluminum - 0.3%, nickel-based alloys - 0.2%, titanium alloys - 0.2%,brass, bronze - 0.2%.
Marin Vujcich posted something similar in the paper he referenced, where it shows 12% chrome having high damping. 12% Chrome = 410 SS = Martensetic SS. So when I see kart mfgs making axles out of 410 or 416 SS (8% damping)…I will think they are actually onto something. Or if I see axles with different wall thicknesses…I will say OK…that is a valid design change. Changing hubs? That also will impact stiffness and behavior. But changing from a steel with specific damping of 1.2% to 4% when the Modulus is the same? I can’t believe you could ever feel the difference when you consider damping of the tire, etc.
The way to tell is to buy some 4130 (very low damping) and heat treat it to Rockwell 32 C, and make some axles with 1.75, 2.00 and 2.3 mm walls. Then do the same with 410 SS (very high damping…and strong)… Then test. The problem is, I do no know where to get 410/416 tube. It might be easier to buy pump shaft (PSQ is very cheap), and have it gun drilled prior to centerless re-grinding. The gun drilling would not be cheap…
I would like to point out that we change the rear track by 5mm and you feel it, which corresponds to roughly 2% of the working fulcrum length of the axle. So small stiffness changes could feasibly be the same. When you are at100% of adhesion is stable the 101% is a slide.
I will say track width affects lateral load transfer more than anything less though.
When you change track width on the rear, it’s not so much an axle behavior/flex/damping that changes the handling, but how the load is transferred from the inside to outside.
Narrower track width, more load transfer.
Wider gives less load transfer.
What makes is especially interesting is with karts, people confuse lateral load transfer with grip. Moving the wheels in, doesn’t actually give more grip. It gives less.
BUT, you’ve increased the lateral load transfer, hence the inaide wheel picks up easier and gives the impression that you have more grip.
5mm is a very large change if you review the math. I think we all intuitively under estimate the significance of “just a 5mm change”. It is actually quite significant. A 2% change in working length of an overhung axle (beam) by moving in the hub/wheel will increase the overhung beam stiffness by about 8-10%.
I am not trying to get into engineering overall kart dynamics. It can not be done. I am a good enough Engineer to know that NO Engineer is smart enough to do that. Vehicle dynamics on car, where you can control each corner independently is diabolically complex. A kart? An order of magnitude more so. So you use trial and error, testing, and experience. One bad habit us engineering types have is dismissing correct answers that were arrived at while not using engineering principles.
But we can break down specific isolate parts of the kart…and apply engineering principles to them. That is why I was looking in detail at axles. The physics just to not back up the notion of softer and stiffer axles being a factor, because there is no way to make them stiffer of softer unless you change wall thickness, which I see no one doing.
There are (or at least were) different wall thickness being used by sone manufacturers. There was also a spate of axles shearing which might have ended that.
@Alan_Dove might be able to talk more about that.
Sorry wasnt comparing the change with axle stiffeness just stating that small changes can be felt when you are near the limit. So small changes in damping will also be felt when at the grip limit.
I think that is an issue in cars as well. We look at static dimensions and don’t fully understand how the effect plays out dynamically. Mix in how one adjustment affect others it coordinates with and we get confused.
I hear 2 basic outlooks from people - in regards to chassis tuning.
1 - each kart is different.
2 - all karts are the same
I know I’m not good enough to say what is right. I do find #2 a more comforting scenario. I tire quickly of the VooDoo approach and think there has to be some basic correlations that are universal. I just want my world to make sense to me.
James,
I have been out of the game for a long time. I recall back in the 90s seeing different axle wall thicknesses, but back then, changing axles to impact handling was not as well known. Today…everyone talks about it, but now the axle walls seem to be all the same. For instance, Birel/Freeline has 5 or 6 axles, and they all have the same 2mm wall. I am just not seeing that there are enough different materials out there to get a real range of behavior being claimed without changing the wall, hence my comments.
I could see going safely down to 1.25 mm wall…IF you have the right material, the right heat treat, and most of all get rid of stress concentrations with a inset spline type mounting system for hubs and carriers. But it would cost $ that could only be justified at the factory level.
Maybe one day I will do some dynamic response testing. I have some pretty sophisticated multi channel vibration analysis equipment (CSI/Emerson https://www.emerson.com/en-us/catalog/ams-a2140) which would allow me to quantify damping characteristics. Mount up an axle on a rigid base…and whack it with a modal hammer, and see the dynamic response…
Good point. At the limit, the smallest factors become significant.
The whole “soft” and “hard” axle has been a mystery to me. I’ve been in karting for 20 years and it still bugs me but…
…recently I found some really obscure mechanical engineering papers (circa 1950s) on large scale damping effects as a function of steel softness and hardness. I think this is where the theory behind axles is but the paper was too much for me. Harder has less damping and softer axles is has more damping.
I read somewhere, well not somewhere but the internet, that in the 50s and 60s Italian bike mfg used different hardness steels to change the ride characteristics of road bikes. Seems logical that this might have made its way to the kart and the axle.
One thing for sure, it’s good for business.
I’m super necro-posting here, but I found myself re-reading through this thread.
Although I still do believe that the ‘spring rate’ in axle is a thing, I will say that as my driving has started to improve, I’ve noticed less of a need to change axles.
That might because I’m pulling a @tjkoyen, and am just getting lazy and driving through things that I might have wanted to tweak before, or I just find a balance that I like, and learn to drive around it.
Necro is good if it continues the discussion and it’s still relevant…
I think for the most part… evidence that axle “flex” seems to be a bit thin on the ground.
But that’s not to sat changing axles doesn’t make a difference. For axles, I think in terms resonance and damping. For spring rate I think more tires and chassis.
I would bet that you’re just driving better and issues you thought were handling were actually driving based. Glad you’re getting there!
A few weeks ago, I worked with @Noahkoenig134 at the track and we found 0.6 in one session and fixed all the handling issues just by driving better.
Here’s an interesting article on this subject.
http://www.strikeproducts.com.au/uploads/Back%20axles%20201011.pdf
The preceding article explains the concepts very clearly, but makes one extremely faulty assumption, ie that the young s modulus of steel is always 200, regardless of the chemical composition or the heat treatment that said steel underwent, or even its thickness. A very quick research online produces several scientific papers, that clearly show that it may vary between 180 and 210.
This paper shows that some specialty steels reach even 245
https://www.tandfonline.com/doi/abs/10.1179/1879139514Y.0000000127?journalCode=ycmq20
So varying quality of steel certainly will affect the amount by which an axle will deform under the same force, ie an axle may be stiffer or softer even without varying its dimensions.
Therefore, changing axles certainly will be one of the factors that influences the behavior of a chassis,
Given the time and effort required to do that, it is clear these days that the most successful kart manufacturers are trying to broaden the performance envelope of the chassis as much as possible. The most successful manufacturers are trying to provide a product that will perform extremely well with a base setup that covers a very wide range of tracks, temperature and tyre characteristics. This will leave just a few small adjustments needed to reach the optimal performance. Tipically axles will be changed very infrequently.
What about wheel hubs?
