Kart Republic Front Bar
I think knowing the rest of your setup would be helpful, along with the engine/tire you’re running.
Generally Kart Republic doesn’t run with a front bar, although I have used it in situations before, notably a very low-grip surface that historically everyone struggled for setup with.
I’m trying to understand what you mean by hopping when hitting a curb. I remember the KR2 being very stable over curbing and haven’t heard of that issue before. Do you know what the wall thickness of your frame is? I know KR has been experimenting with a few different types of wall thicknesses over the past couple years
The frame design of the F03 is the same as a KR2, though with BestKart’s (AMV) material and components.
We’ve had KR drivers test the BestKart say it feels pretty similar, though the feedback has generally been that the BestKart is a bit more rear-biased. They tune very similarly.
How is the tuning on the BestKarts? With Olds a couple years ago we were way out from neutral to get the kart fast, but it seems like they’ve made improvements the last couple years with getting the karts to stay closer to the standard tuning setup
Nothing too crazy. My baseline right now is low front ride, high rear, and half caster. Everything else is neutral.
I heard KR1. All 32mm with 1.6mm wall thickness.
Back In the day the AMV/Bestkart was made by Parolin and the design do not look like it has changed since then.
The AMV kart was easy to drive and setup as i remember it.
FIA regulations have a minimum wall thickness of 2mm. USA regulations vary depending on the promoter. I have seen regs with as low as 0.060" (1.5mm) for 1.25" (31.75mm) frames and no mention at all. For example NKA doesn’t specify a minimum wall thickness (in the regs I have from 2022) but they do state:
“20.2.1: Homologation
Chassis used in series competition are not required to be homologated but are expected to generally meet homologation standards set by the CIK”
So are KR making a US specific frame now? I’m sure its worth it.
It was rumored in Europe that Parolin where using 1.8mm or 1.6mm for the cadet frames at one point.
I’m not surprised. Like I said, for whatever reason NCMP is a unique track in terms of what works well out there.
I would heed this input. It is from one of the principals working with DPK Americas FA kart endeavor at the national level.
