Price: $975
Pictures: Pictures
Details:This is for 2 engines and parts listed below.
(1) Rotax Max 125 Sr. Non-Evo engine 5 hours since a complete rebuild, comes complete as shown.
(2) Engine: Rotax Max 125cc Sr. Pre-Evo, I do not have any history on the engine. It will need a few things such as the starter button and power button will need to be installed, which is included. Throttle Cable, which I will include a new one. I will include a new battery which will it will need to be installed. I have cleaned the carb and replaced the gaskets, but would recommend a once over of the rest of the engine prior to starting.
In addition to the engine it was also come with the following parts:
· (2) Starter
· Used Piston
· Engine Gasket Kit 298020
· (3) Clutch Drums (2 drivers)
· Various Clutch parts
· (2) Exhaust Tubes
· Used Radiator
· Exhaust
· 296161 ROTAX GASKET SET CYLINDER ASSEMBLY
· Rotax Evo 2 Max Kart Upgrade Ignition Coil Support Mount Bracket Kit 481257
· Used Fuel Pump
· Carb Gasket ROT293834
· Used start push button
· Used plastic Gears
If you have any questions please let me know.
