My sons cadet kart and my full-size kart have 12mm holes for the kingpin pills. Currently they are hodgepodged together with a random eccentric pill on one side and a 0* pill on the other. All of the kingpins are bent to some degree.
How can I tell if the spindles are also bent?
Is there a pill kit for the 12mm holes that you would recommend? I’m not having lots of luck searching. Most options are for the the 22mm adjustable styles.
