does anyone here know much about pcr engines? i found one for 600. are the parts available.? thanks chuck
Parts are pretty interchangeable on the 90’s 100cc engines. At $600 I’d expect it to be pretty fresh.
thanks, james how about clutchs that can be used.
I’ve always run them direct drive so I’m not sure. I would lean towards a jack shaft setup if I was going that way. Then you can run an appropriate clutch without worrying about it being too heavy on the crank.
I ran a parilla tt 23 direct drive in 78. but im to old for that these days. ha ha. thanks for your help james. chuck
