Hey all, new member here. I have a 2008? CRG and I have an opportunity to upgrade to a 2016 KT2
I wanted to know what upgrades you are all aware of between the two, trying to decide if it’s worth the hassle. I assume one advantage is availability of parts. What performance upgrades happened between the two?
Gotcha. The kart in the first photo is lacking a homologation plate so I’m not sure exactly what model, hoping someone can identify.
Will be running LO206
Thanks
Do you have reason to believe that the current chassis is limiting your performance? If so, and if the newer one is a great deal, then I say go for it. But if you’re not at the top of your game driving wise, then a newer chassis may not get you any closer to the pointy end of the field.
Those older CRG’s are built like tanks, so I wouldn’t worry about it being worn out.
Solid point, my reasoning is mostly availability of parts for newer models and I assumed better resale and longevity. But good to know that the older models are solid. Thanks
Adam – I do not know if the CRG KT2 from 2016 is the same as the one from 2020, but I bought one that year and it’s the best chassis I’ve ever owned or driven. I’m now using a VLR 100 engine and the chassis is lively and responsive. My original kart was a CRG Road Rebel with 32/32 tubing. Went to a Zanardi 32/32, then another CRG 32/32, and finally (before the KT2 at 30/30) a Zanardi 30/32. Probably all were too stiff for the Rotax engines I was using. Now with less horsepower and a slightly lower weight class, the CRG KT2 is crisp and lively. It may well be an excellent choice for a 206 as well.
Went for it and sold the 2008, got the 2016 KT2 today and it looks way more advanced. Very excited to get it ready for the track. Pic has the front bumper taken off, but scored the stand, backup plastics and wheels/tires.
