Hi all,
Just wanted to see what people’s thoughts were on a couple flat spots I noticed on my tony kart(401r) , and if I should be concerned with the longevity of the chassis?
I got the chassis used and only used it for half a season (KA100 sr class). The kart felt good but I noticed two large flat spots over the off season that were covered up by frame guards from the previous owner. These are located right behind the front spindles towards the front of the waist area.
I measured the outer diameter and largest width of each flat spot. Below are the measurements.
Right Side
DIA: 29.78mm
Width: 8.79mm
Left Side:
DIA: 29.83mm
Width: 7.75mm
