Ryon raises a good point. What’s different in terms of driving experience with this new 250 (Assuming KTM’s OEM) vs the single cylinder “ICE” engines, or even the plain old CR250. As fun as the CR250 is to drive, it’s pretty lumpy and doesn’t like overrev at all.
Six gears? Wet clutch? Analogic igntion? Carb?
If the testing is done, this info should already be known
Hate to be a pest, but like I said, this is a bit of a tease post, not to mention it’s leaning on the commercial promotion side of things
So how does this work exactly? Factory convinced them to sell a bunch if engines and will run a local series based on that? Or is it bigger? Straight to national level stuff?
They should just copy 250 National here. Extend wheelbase. Don’t de-tune them. Make it a class for old-timers who want to go fast and not have to mess about with KZ. Just lay back and chill a bit. Obviously here a lot run long-circuit chassis but Jade have a Birel with longer wheel base.
The older I get the more I appreciated what 250 has to offer. Just for everyone’s interest here in the UK they will run different track layouts. This is helped because most of our tracks are old RAF Bases so skipping a chicane or extending a straight isn’t a big deal. That way you’ve got a bit of an advantage over a KZ in some form. Just make it an around different experience for short-circuit
Here on the US east coast, we barely have tracks that are big enough for kz driving. Unless you do road racing I dont see a 250 showing up on a sprint track any time soon here.
Oh, it’s absolutely a tease post, and absolutely commercial advertising. If the teaser is outside of the scope of this forum, you’re welcome to drop this thread, and if you’d like me to cut a check for commercial advertising it might be available.
Five gears, wet clutch, electronic high energy ignition, 38mm carburetor. If you don’t like the sound, the manufacturer also builds excellent saxophones.
Closest track to me I have my lowest speed gear ratio on my Modena and I can’t even get out of 5th gear! Tops around 55mph lol, KA100 are almost faster than kz there
