Air box fuel Rotax max
Air box full of Rotax max fuel, what is it? Engine no longer starts, fuel comes out of the box.
Possible jammed float or dirt in the inlet needle of the carb possibly. Some fuel in tge airbox is not super unusual…. It sounds like you’re seeing a lot?
Definitely check the floats. I had mine stick and it just started spitting fuel out of the breather hoses and front of the carb.
Perfect ! Thank you so much
yes, a lot of fuel coming out of the air box outlet. I removed the box and when I started, all the fuel that came out came out of the carburetor through the outlet to the box. I’ll check the fleet tomorrow.
Many thanks! I’m checking the fleet tomorrow.
