Best shifter engine no need to maintenance?
Hi guys,
I’m a national driver, I do races with official team. I’m thinking about buying a shifter engine to train myself on wet, so what I need is only durability. I don’t mind if it could be slow, old and what manufacter is. My goal is only to run on wet track and save money (both for the duration, for the cost and maintenance time, and for the purchase price) What is the best engine for this?
Thanks
Does it have to be 125cc?
I heard from some people in my track that the IAME 175cc X30 shifter is pretty reliable, only needs bottom end every 36hrs. Since you’ll only be using it in a wet track it can definitely last quite a few months. I’m not aware of prices in your area, but used karts with this engine aren’t too expensive here.
I’m guessing you’re not in the US, but if you are a Honda CR125 (kart prepared) would be maximum bang for buck. Or a CR250.
CRF250 (the four stroke) would give similar performance to a 125, but for training might not be ideal if you’re racing a two stroke since gear selection is more critical with the 2t
But realistically kart engine wise I think the 175 as mentioned would be a good way to go. Rok shifter could be an option too.
Yes I’m looking for a 125 2t, right now the 175 is not an option. I’m fron Italy, here engines like Honda, 4t and 175 are not used. Rok shifter may be a good solution. How long is the durability? Aproximately
From what I read online, a good rebuild interval for the ROK shifter is 10hrs top end/20hrs bottom end. I don’t have experience with this engine but it sounds reasonable.
TM KZ10ES. Service intervals: top end @ 100-140 L (26-37 gal); bottom-end @ 400-440 L (105-116 gal).
TM KZ10ES or ROK Shifter (in that order).
TM KZ 10B if you want the performance, reliability and super low entry price (which buys you rebuilds). If you are driving on wet you won’t be jetting it too crazy so it will last quite a bit.
Factory FZ250. Pump gas, cheap outboard motor oil, 50 hours on a top end, crank and rod replacement when they rust out. About 49 hp.
I’d REAAALLLLY like this to be a spec superkart class…
Do you know where do they sell the TM KZ10ES?
Unfortunately engines like KZ10ES and FZ250 are not available in Italy…I’ll go for a ROK
Show up at Via Fermo 43 in Pesaro with a couple thousand euro in your wallet and you’ll probably leave out the back door with a KZ10ES
Yes, of course, but I’m looking for a second hand engine. I can’t spend 2.000€ for something that I need to train myself on wet
+1 for rok shifter. They are quite reiable, parts availability is good, and with the stock pipe and jetting configuration you still run it very safe. Would highly recommend.
You’re in Italy, so not sure.
