I am interested in adjusting the front ride height rear axle … The track has no traction
High Grip is going to be for a high grip track. You want the “Low Grip” setup.
B axle, longer 1060 if high speed circuit. Don’t touch front ride height. If you more initial high speed turn-in then go to stiffer stubs (pink is good). Standard front bar, and you could try middle ride height in the rear.
When you say the track has no traction, what do you mean?
Is it over steering? Can’t get the power down?
How old are the tyres and what tyres are they?
