hey im new to karting and i was wondering if i can use https://www.autozone.com/test-scan-and-specialty-tools/brake-bleeder/p/duralast-one-man-brake-bleeder-kit/1267199_0_0?searchText=brake%20bleederas a tool so i can bleed my brakes, sorry if i look dumb for asking i just dont know that much :edit i notice i put the wrong link
No problems
(20 char)
I would say its possible to use that set up. What brand are you bleeding? On bicycle disk brakes we use syringes at either both ends or one end with a reservoir. Most of these kits have adaptors that can work with kart brakes with a little trial and error. It’s certainly cheaper than the gravity bleeder. Aliexpress sells cheap versions of the bleeder kits as well/ Even a cheap non o-ring syringe creates enough pressure to bleed brakes.
I’ve seen someone using one of the bleeding tools you mention. It seems to work quite good.
I now use a vacuum pump which makes bleeding brakes very easy.
