How much slack is the rule? I adjusted the brake lever to fit me better and now that cable is way too long. I could put it back to where it was when I did the lever, but its kind of a guess and I want to be in spec,
Thanks,
Thanks,
The safety cable should loop back on itself and held in place with a clamp. Loosen the clamp and pull the excess cable out.
Thanks Tony, mine has a straight cable Threaded on each end.
