Hi guys. I recently bought a fullerton tf2 and i want to take it out for a test soon. My question regards to the castor pills. I have adjustment on the top but nothing on the underside. Is it good to have adjustment on the underneath pill? Should i look at getting some? Do all pills fit all karts? Senior if that matters.
Thanks guys
Having a pill on the bottom doubles your range of adjustment. It’s a good tuning tool to have but not always necessary.
Any BirelART pill should work. Often other brand pills will fit the hole in the yoke but sometimes the set screw holes don’t line up between brands.
If the Fullerton uses Freeline stuff the Hole In the C`s are 23mm, wheremost other karts uses 22mm.
Freeline offers 0.5, 1.5 and 0mm offset pills.
Thanks guys. Ill just get 0.5 if i can find it online somewhere.
