CES sprint/enduro bodywork
Does anyone know if rear deck covers are still legal in CES? I recall one track I couldn’t run it, it might have been because of host club rules. Looking through CES rules I don’t find anything that says no.
I’ll need to have the new exhaust pipe custom bent to run above bodywork. Just want to make sure the rear deck is ok before having this done.
Never mind the Tecumseh in the photo, it’s going to run on a Kohler.
173D0838
http://www.championshipenduro.com/index.html
Thanks Tony,
I had read the rules, and did’t see anything stating rear deck was illegal. Only thing I had seen was the 1 inch rule from the seat. That could have been the issue I had in the past at one track, of course it was my home track RA.
Dan,
We haven’t run with CES for a few years but seems that the laydowns had the rear decks. Can’t recall them on any 2-cycles and I’d just be guessing on the 4-strokes. Contact Dave Larson to be sure.
Tony,
The photo was from early 2000’s when all I ran was CES. I never had an issue but the one. Stallion did the bodywork for me with CES rules in mind. It’s probably good to run. I’ll try reaching out to Dave.
If memory serves me correct, you and your brother ran KT100’s. Myself and my racing partner Ron had stopped at your shop back in the day.
Dan did you ever get an answer on this from Dave at CES?
James,
No i didn’t talk to Dave, but this is from the rule book.
Sprint ENDURO specific bodywork requirements
  1. Height from ground level of all side panels and rear pods: 16.0 inches maximum.
  2. Except as noted in section 4.j.5, no part of the driver’s body may be covered by any bodywork component, as viewed
    from above.
  3. No bodywork component may extend aft of the rear bumper.
    4. Distance from seat to any bodywork component: 1.0 inch minimum.
  4. Lateral distance between bodywork components in area from the mounting point for steering wheel to the point where the
    seat rises above the side panels: 22.0 inches minimum. If the seat remains below the side panels 22 inch minimum
    distance applies from mounting point for steering wheel to rearmost part of seat.
  5. The nose cone may be no narrower than to expose one half of a tire width per side.
  6. A connecting strip from nose cone or floor to steering fairing is allowed up to 6.0 inches maximum chord width, so as not
    to cover the driver’s feet, or legs. Minimum six inch clearance from connecting strip or steering fairing to any other
    bodywork component begins three inches maximum aft of the pedals, extending rearward to the mounting point for the
    steering wheel.
  7. CIK style nose cones and side pods are allowed. The use of CIK mounting hardware is not mandatory.
  8. Tire recess: All or any of the four wheels may be inside the bodywork a maximum of one inch per side, regardless of
    bodywork configuration. This measurement shall be made square to the outer face of the tire nearest the bodywork
    component in question, wheels straight.
There are very few karts with the rear deck on them in CES. Most don’t have one.
Why do you want one? If you do use one I’d make it removable just incase.
It already has the rear deck, it was part of the bodywork package. I do have Dzus fasteners on it, so it’s removable if needed. The question was if they still allowed them. Reading through the rules I found an answer. Basically run it until asked to remove it. I interpret the rule as being legal.
