Cold weather, which wheel/rim? Mag.? Alum.?
Hello KP members, we are now entering a cold weather period in Brazil (18ºC in average is cold for us) so I am looking for a set of wheels to help keep tire temperature above 80ºC . I usually have DWT M-SERIES – LV (LOW VOLUME) in the summer period and it works fine, but it seems to be too much ventilated for the winter. I was wondering about a less-ventilated wheel or maybe a different raw material. Any suggestion?
18C is not cold enough to require a drastic change in wheel construction. I’ve run MXCs in 50-100F with no issues.
If you wanted to try something else, a standard Douglas magnesium wheel, not vented, might be a good tweak. But definitely don’t need aluminum for 18C.
The AMV line has a lot of options as well and I liked my 3Fs I ran last year. They might be good for those conditions as well, as I felt they ran a little hot for the racing I did with them at 70-80F ambient.
When you say Standard Douglas Mag you mean the first or the second one in the picture below?
Either one is probably fine. But the vented would be my choice.
