Essentially they are the same engine with slight improvements to the components to each higher number.
To echo @Rdub3 , why are you switching? The Honda is more reliable and consistent. On the other hand, the Comer revs higher and forces the driver to be smother to keep the revs in working range. Like everything in karting, its a trade off.
I’ve seen my son race against other kids with the comer and there is a difference in acceleration.
I’m just curious to know what the different components are and how they make the car better. If you have time to share that would be appreciated thanks.
I do not know the specific changes to the C52, but between the C50 and C51 is basically the kill switch on the front cover, otherwise basically the same. As for performance between the comer and the honda is, like I said, a trade off.
The comer is two stroke and the honda a four stroke. Two strokes have narrow power bands compared to four strokes. Comers have to keep the revs in the power band range to pull well compared to the honda. The comer forces the driver to be very smooth, but rewards with higher overall revs (where two strokes shine). The honda is more forgiving. Say you bobble the braking zone and overcook the corner, the honda has the grunt to get you back to racing speed faster than the comer can.
In terms of proper race training, the comer is more effective, but harder to master.
Actually in my experience the Honda pulls out of the corners worse than the Comer. It’s faster on the straight though (at our track anyhow). We had a couple years where we ran both together, but now only the Honda. If a comer shows up they can run, but not for championship. Everyone has been much happier after dealing with the temperamental comers for so long.
Correct, but there are 2 different gearings that can be spec for the Honda, usually once the track sets it that is the spec. I think it was 2 different clutch sprockets? I know we had to figure out which one was the best fit when we first started running them. Also one thing many people do is go to the super skinny rear wheels too early. With a wider wheel like a 5.5 you can change the ratio and get some more out of the corner, obviously a loss on top speed. Keeping the engine in it’s effective rpm range is more important though.
