Hey there, would anybody know what kind of brake bads I should use to replace my current ones? Also are there any known dealers that can provide spares? Thank you.
Whereabouts are you located? With that info someone might be able to point you to a local CompKart or BirelART dealer who can help you out.
Aside from that, J3 Competition owns the CompKart brand. You can also always give them a call and they should be able to hook you up with what you need.
The Freeline/Compkart pads are available from many sources. These pads work well but they are expensive and sold individually. Sinter makes at least two versions with the red compound being the most common. These are sold as a set and a set costs the same or less than one Freeline pad.
I have found the lowest price for Sinter pads at Fastech Racing in Las Vegas.
If you want Freeline original they can be a little harder to find but PSL karting out of Canada I have found to have the lowest prices and they occasionally will discount all Freeline parts.
I’m in Australia, and while i’ve heard of some places that apparently deal parts, they only do very limited parts
Mondokart lists Birel (freeline) brake pads. I don’t see aftermarket but they have the OEM pads.
