Someone turned into me and cracked my rear right rim. It’s a stock freeline magnesium one.
Does anyone know if it’s possible to repair it? At this stage my only option is to buy a new set which is close to AUD $930 (apparently you can’t just buy them individually).
I would imagine the cost of getting it repaired would make it almost more beneficial just to buy a new set of wheels. I have to imagine there are plenty of used sets of wheels or a single used wheel you could buy instead of getting a full new set.
I’d never run that wheel again. Some champs/races also have rules against ‘welded’ wheels and that kind of thing. As TJ said, plenty of used sets out there. Just gotta find someone selling one or a pair.
Cracked rim make a good campfire, just make sure you break them into smaller pieces. I toss mine in as a whole, neighbood though we were doing some witchcraft.
Since you can buy the singles, you can still buy a rear set only from a different brand that is cheaper (Douglas, OTK etc). Pick a similar design and you will be close. I’ve seen plenty of people running different sets front/rear, some on purpose, some not so much…it works
Magnesium is considered to be in the Class D Fire category . It has a melting point of 1,202 °F and a boiling point of 2,024 °F. When magnesium is in its metal form, it burns very easily in air. When the magnesium burns, it reacts with the oxygen to form magnesium oxide.
Magnesium burns a very bright white, so it is used to add white sparks or improve the overall brilliance of a firework . Sodium imparts a gold or yellow color to fireworks, however, the color is often so bright that it frequently masks other, less intense colors.
We for sure had the best/brightest firework in the park that night. Here is short clip, half the rim went straight to melting instead of burning and I saved half of rim with my marshmallow stick.
I call BS on not being able to buy them individually. Find a local Birel/Compkart dealer who will play ball. I’ve had to buy a single Freeline wheel before. Broke mine in the exact same way.
