CRG RR 2023 chassis setup for very slippery track. The track has no traction
What kind of handling issue are you experiencing? I can hazard a guess (Push/Kick) but it’s better if you describe it in your own words.
The problem is that it is very slippery in the back. I drive with an M20 middle axle. I am interested in settings on the front rear axle
And another question I have about the CRG softer rear axle than the m20 when used
I believe this is 32mm? In which case I used to run a T2 axle on my GP14 chassis. Also over here in cold NZ, most run with long magnesium hubs. Perhaps some options to look at if you are struggling. Also 2 seat brackets per side in addition to the chassis bracket.
