Im looking at picking up one to make it easier to load my truck. Does anyone have one and how do you like it? Do you have the full electric setup one or the unit that runs on a drill?
Im having a hard time deciding if the $100 more is worth it or if the drill setup seems a bit simpler and better.
Yes they are pricey but not much more than a Streeter. Im mainly looking at it because it folds up and I can lift it into my truck bed. Now I just need to figure out if it lifts the kart high to get into the bed.
Yep exactly the reason that I’ve choosen mine, it’s one of the lowest when folded and I can easily fit it under the kart. Mine it’s not high enough to arrive at the kart so I manually pull out the kart a little bit and lay the rear bumper on the two hooks. Just a bit of caution is required when lowering it down for the first time but once it’s on the floor you can hook it properly.
Considering one of these fully Electric Dalmi… For an adult lo206, is it worth going with the bid wheels version or the even more expensive Fastech Exclusive Big Foot Version?
I went with the standard castor wheel setup from ItalianMotors.com and its been working fine. Takes a bit more muscle if your on gravel but its worked out great for me. Also looks like the price has jumped a bit from a couple of months ago.
I got the “bigfoot” model precisely because larger wheels make moving easier on any surface, & especially rough surfaces. I must admit, it was pricier than the rest, but still worth it, IMO. Of course, it doesn’t hurt that I bought “way” back in 2019 when they were roughly half of what they cost now, thanks to government debt spending & central banking monetary policy for depleting currency values.
