The floats on the vhsh are seperate pieces from the leverage arm which operates the inlet valve. The height referenced is the height of that arm when measured from the bottom of the carb where the bowl seats. They make tools which make this measurement easier, but basically pull the bowl off with the floats, turn the carb upside down and measure from the metal arm down to the bottom of the body (where the bowl seats).
