Ok, looking for solutions as Google has failed me. I have a used KA100 with the recessed 5mm bung. We run Alfano and all I have for Alfano that have the external nut designed for a larger raised external threaded bung.
What the heck are my options to make this all fit?
I am going to test mine versus 2 known temperatures to confirm. I have a probe thermometer I can use to check against, or I can shoot the surface temperature of the TC tip with IR gun for cross-check.
If done correctly the junctions should not skew the readings. Both manufacturers use K Type TCs, so just need a Type K plug end (yellow). Also, Type K should mean red wire to the negative post of the connector and yellow wire to the positive post. Done this many times on gas turbine, boiler, and combustion system TCs.
