Make and model of chassis
Emmick tag kart
I need help with
Rear axle hub lugs replace or whole new hub?
What I’ve tried so far
Nothing
If you can extract that broken stud, you can replace them for now much money. https://www.accelerationkarting.com/8mmwheelstuds.html If you’re going to go that route, I’d replace all of them.
Also, I’ll PM you about it too.
You might try purchasing a screw extractor from an auto parts store. Since the original stud was installed with a thread locker, you might not have much success. But its worth a try. Good luck.
You should be able to remove the stud withaa EZ Out.
