Hi Everyone
Would I be able to run the Evo exhaust and carb without getting negative impacts on power
Any help is appreciated
I run the carb only on a DD2 no evo , it’s a definite improvement, the power is more progressive. It’s a bit strange using such a small jet but I believe that it takes fuel though the carb body. Jetting is not so important.
Like Jessie said you should see some power gain with the new carb as long as it is tuned properly with smaller jetting. The new exhaust is better as well.
yes, just make sure you run the evo jets. Not sure if non evo jets fit but if they do make sure it’s the evo ones 122-128
