Hi guys,
More rookie questions… I have a KZ CRG Road Rebel…… if I Sniper align on the stand, what changes do you see after putting the kart on a level pad with driver in the seat ?
Particularly interested in changes to toe and camber…
Measure the distance between the top of the Kingpins on the stand and when the kart is on it’s wheels with the driver in it.
If the distance measures less when on the ground then your frame has flexed and then as @DIG78x said above you’ll probably show more camber. If the distance is the same the settings shouldn’t have changed.
OR
Set it up on the stand and then leave the snipers on the stubs, if that’s an option with wheels on, and see the difference.
