Hi all, recently bought a secondhand 2023 Magik Condor Evo 2 chassis (KZ) with Italfreno brakes. The pads are a bit worn and tapered so I want to get some spares while it’s the off season (I’m in Ontario Canada) but I cannot find a match.
I’ve heard mad croc parts should fit as the chassis is also made by EKS but on mondokart, the measurements are 2mm longer than my current pads, which are 40mmx40mm and hole spacing is about 27mm on centre.
If anyone has input on which ones would fit please do let me know (especially from mondo as I’m due for an order anyway) before I take a chance on the crocs and have to get the grinder out! Thanks!
