How do Lando slide his kart this way?
How do Lando slide his kart this wya?
What slides? I dont see any slides tbh
You can find his heavy braking at about 3:10.
He’s locking up the rear brakes.
I know, but how can he slide so straight?
The lockup is pretty normal behavior unless the kart is WAY out of balance from side to side. It will bob and weave a little, but usually pretty controllable.
By modulating brake pressure and making small steering adjustments as the kart wiggles. Basically reducing brake pressure slightly as kart kicks a bit. Like abs. My 2c. Try it. Lock up the brakes with wheels pointing straight and then try to have the back stay in line as it wants to wander. As the kart slows you’ll have to reduce brake pressure on the way down to zero forwards motion.
For the lockup he’s 100% locked with no modulation from what I can see. The wiggling that’s going on is more from the bumps and surface changes.
You may be correct. Who knows. Send it and see what happens. What I can say for sure is you do have to release eventually or the back will take over.
