I put in a new front wheel hub. The old one I would call free spinning, it’ll spin for 10+ seconds easy. The new one will only spin for a few seconds before stopping. Is this normal?
Loosening the nut has no impact. Am I supposed to grease either the bearings or the spindle? Will it loosen up over time? I noticed the inner bearings don’t really spin, but rather, the whole hub spins as a unit.
They are usually a bit tighter when new. Take for a practice day and it should loosen up. Worst case toss a couple new bearings. Cheap but likely just needs to be broken in.
My son and I timed how long the front wheel on his OTK would stay spinning when spun by hand. It kept movinb for over 3 minutes before stopping. The kart was about a month old at the time. I had bet 30 seconds tops and was blown away. I never checked without the wheel installed.
Yeah, on the stand, the new one stops within 5 seconds, the old one keeps going for a while. It seems like it would rob power if it’s not free spinning. I will see if it gets better after a practice day.
The bearings don’t seem to play a factor? The whole bearing seems to spin right along with the hub (as opposed the inner race staying still and the bearing itself spinning).
