Looking on the forum I couldn’t find another topic that covered it.
I feel like my brake pads on my OTK wear out abnormally quickly, I’m using stock pads and bled the system twice. I’ve gotten much better about dragging the brakes however one set only lasts about 80-90 laps before they drop off. I don’t really know if they should last longer or if that’s normal as I don’t know a baseline I should compare to.
I can go almost a season on a set. But I know some (fast) guys who power-brake more will change weekly.
I have done about 10 days on my current set and they were used when I got them. I miiiight throw a set in for the USPKS race next weekend but I think there’s enough meat on them for a couple days yet.
Certainly in 206 I would imagine they would last forever. If you’re burning through them quickly, I would double-check you’re not dragging them much, and if necessary you can get the harder pads too.
Wow. Those must be some really aggressive pads. How often do you replace your rotors?
I guess they last nearly forever on a shifter due to engine braking downshifting. One set easily lasted me a season. I never knew they were such a consumable on a single speed kart.
Home track has some extremely hard braking zones. A Friday practice/Saturday/Sunday race day usually has me around 50%. I’ll practice with them. But race weekend equals new pads. This is x30.
206 I recycle all these sets or sell them for dirt cheap to people that under estimated their brake pads. Ka I get way more use as well.
Edit. I should have clarified each race weekend. For practice days or single race days some times I’ll leave them. Also only on my x30 generally.
black = hard compound. Needs very high pedal pressure. For me hard to modulate as they need so much force. They lack on grip to lock the front on a shifter. After using the same set for many days - there was only slight step visible on the pads. These pads last for ever
red = soft compound. Less pedal pressure required. Easier to modulate. I like them. The kart stops harder, the front end starts to chatter before locking up. Plastic parts are shaking, the front drops - all the good stuff. They wear down fast. After each day - there will be a step in the pads
CRG makes also super soft pads. Black in color. Havent tried them
Has anyone been using the cheaper “sinter” pads from wildkart ? How do they compare to crg stuff ?
Yet another example of ridiculous Aussie superiority. It probably works just fine with the cheapest fluid you can get at AutoZone too.
Somewhere in Australia Drew Price and Dave Sera are helping the boys unload another container of OTKs and thinking “we could do so much better, we have done so much better…”
