I bought a used OTK with a 1000mm neutral axle. We want to test it out vs our current LM30. It was suggested that I widen out the rear, but I’m running out of room. How much of the hub is recommend on the axle before you risk handling issues, or worse, losing the hub?
I have about 1.75 inches of hub/axle contact currently.
Nice. AMV 3F is a great starting point in terms of grip level, and also has the same backspacing as OTK wheels, so shouldn’t be a problem to keep plenty of hub on the axle.
