Seeking your collective input on how much lead I should be adding. I’ve just clicked the go button on my first race at the end of the month
I’ve got a PCR with a rotax evo, & the plan is to race TAG Restricted Medium (187kg)
I weight 88kg myself so trying to get an idea of how much weight I should be adding to get me over the minimum weight requirement
Bring more weights than you need to the track. Have them drilled before going to the track and have long bolts to attach them. At the track, weigh the cart with the minimum amount of fuel you want to have after a race plus you and your race gear. Scales from one track to another will differ as well as the same scale at the same track will differ between weekends.
Good luck.
While we are on the topic, is gas level a preference? I run about 1/4 tank thinking I don’t want the weight up front up high so use weights to balance it out. Not sure if that is ideal but curious as I think it’s relevant to the “how much weight to add” thread
