Do you find yourself having to adjust the idle on the 206? I find I have to do mine when I fire it up, but admittedly the weather and temp is fairly different each time I use it.
How often do you find your idle needs a tweak?
I was able to find a sweet spot and leave it through out the summer. I tweaked once or twice in the fall especially cold morning. I guess I am more like do not touch if it is running people.
I don’t idle, that’s what the pedal is for.
Virtually never. I have idle air screw very rich and idle probably at 2k. I do not remember.
Idle screw is backed almost all the way out. It does nothing.
That doesn’t sound good
Noob here: what is an idle?
The little needle that makes the kart keep running when it’s standing still. You twist it. Or in my case look at it confusedly.
Idle screw, whats that? I just tighten my throttle cable ever so slightly, lol.
I keep the idle on the high side with my kids kart. I don’t want to risk it stalling if they spin out in a race. Sometimes tgey csn recover from an off track excursion but not if the engine stalls… that being said I probably only adjust it when there is a large change in temperature and the idle is way off. Or whenever I make a carb. Change or adjustment.
