Does anyone know how to test a stator to see if it is good? I have no spark and the coil is New.
Other than replacing it, I haven’t found a way. Check other things too if you have no spark. Disconnect the kill switch
Make sure your ground is good
Make sure the magnet on the rotor doesn’t have anything stuck to it
If you replaced the coil did you replace the plug cap?
I replaced the plug cap with one that was on a leopard coil. I did have spark. not now
The IAME one is silly expensive at $23. If your track allows it, NGK makes a plug that cost $4. Since it is not an OEM part it may not be allowed for some races.
