got to work and drive an X30 but Im wondering which series is more budget friendly and better to run rotax or iame, might be planning to run a season soon
Rotax typically goes longer between between service intervals, but the service tends to be more expensive. Overall though I suspect the Rotax will be more economical. You can run up to 50hrs on the Rotax. Emphasis can, performance drop off can be expected of course.
most likely going to be using a used rebuilt engine but I already know how to work on karts so i feel like iame will be cheaper since ill be doing most of the maintenance
I recall Jerry (ran team) talked to me about possibly switching to rotax to avoid doing rebuild mid season. At club levels you can run the top end a lot longer than x30.
The power band was unsuited to our series so it was a non starter ultimately. Plus, to James point, I think they are more expensive to rebuild because don’t you have to have a “certified” person service and seal it back up? Isn’t there a black tie or something that shows it’s been serviced in an “authorized” fashion? Or am o getting engine packages confused?
But yeah, I heard the 50hrs as well.
Rotax needs a service center to repair or change piston and they seal it with a black tie to certify it was done by an authorized person whereas X30 that’s non-existent, you can do it yourself.
Iame you can do it by urself but rotax must be serviced thats whats conflicting Iame lasts less but i can do the work myself but rotax lasts longer but I have to pay a hefty price for a service
