I bought a complete 2011 crg besides the frame because it was cracked and throw away, I forgot the model it was off hand. Now i acquired a very clean 2011 black star frame and began the assembly and have run into an issue with installing the sniper adjusters. I didnt realize the black star used a different setup but have seen pictures of the snipers on 2011 black stars so im a bit confused.
There isnt much info out there at all about installing snipers onto older crg chassis but hear the mounting screws need to be 100% parallel with the frame otherwise it can never be set up correctly? I can drill and tap no issue but to have it 100% in line does have me a bit worried. Is this true as i assume it was affect proper caster setup? Nobody said exactly why it needs to be in line perfectly.
Secondly my lower spindle pill doesnt have any holes in them? From what i see in all the sniper kits is that this piece should have a hole in it to secure to the frame. I mean they look neutral and do i need to get other ones with the hole to secure it?
Id very much appreciate any insight on my issues. - Nick
